- Joined
- 12 Jun 2020
- Messages
- 17
- Reaction score
- 0
- Country
I will be putting in a new ground bearing concrete floor in the existing house but due to footings with tree proximity, the extension will have block & beam.
Floor make up will be concrete floor then insulation to match the height of block and beam insulation, finished with screed for UFH over the top of both.
What is the best way to transition this. I will be taking out the back house wall at one point, but thought if the new concrete is kept within the existing 4 walls.
Then when the time comes for the extension, the wall removed for the block and beam, it can extended on to internal cavity wall set at the same height of the concrete.
Insulation can be placed over the transition.
Is this the best way?
I imagine the screed could crack here, can you put an expansion gap in screed and is it wise too?
Thank you!
Thank you!
