- Joined
- 27 Sep 2023
- Messages
- 2
- Reaction score
- 0
- Country
Hi DIY Crew!
A new 15cm concrete base + prefab sectional garage will be built soon in my back yard. It's a 5.61 x 5.56 m double garage.
Base is going to be raised over the garden terrain, thus water should relatively stay away from the actual garage floor.
However, I understood that concrete panels will be layed down over the concrete slab. Then I should go around internally and create a small lip around with mortar in order to stop any chance of water coming into.
I was looking at possibile long term solution for this issues. My Thoughts:
- firstly, use external sealing between base and concrete walls with some high-end mastice/hybrid sealant.
- a 5/10mm of self leveling coupound ( https://www.screwfix.com/p/no-nonsense-floor-levelling-compound-20kg/453hu ) in order to fill the gap between concrete panels and concrete slab
- Lastly, some rubberised paintable membrane on the external areas to ultimate the sealing process.
At the moment I'm looking for some advice and if someone can explain me a bit about the SBR+ priming process for the self leveling screed. Tried to find some information online, however, I found some mixed results.
Thanks!
Thanks!
