hi i want to cast my own concrete gravel boards for fencing and would like to know what mix is used
oh yeah is this normal cement or the snow cement
thanks col
the mix (probably a tried and tested formula) is put into a cast and aggressively vibrated to work out any air in the mix. you will also need to include re-bar too.
you will have limited success without these pointers, as the boards will snap like biscuits.
it is cheaper and less fuss to buy them ready made.
