concrete mix for shed roof...not as mad as it sounds
23 Dec 2013
Bristol
Ive got a concrete slab shed roof with a block work wall around the top.
When it rains, it fills with water.
There is a drainage point but the rise and fall points AWAY from it!
I want to lay a mix of concrete to create a valley and channel the water towards the drain.
What mix should I use?
ratios?
Im thinking of adding CEMENTONE integral water proofer?
Then painting ACrypol on top (when dry)
Any pointers advice on the mix ratio?
1:2:4, with fine granite spar.
Mix some PVA glue with the mixing water, and also coat the top of the existing roof with the same mix immediately before applying the concrete.
