Concrete raft for conservatory
20 Dec 2004
Hello peeps
I just ordered a DIY lean-to/ conservatory from Wicks and was planning to put it on a concrete raft. It has full length wall panels so will not require a dwarf wall. The base will be 3155mm x 2715mm and a depth of 200mm and will have 9mm mesh wire reinforcement. I am hoping I can place the raft on already in place, well bedded, paving slabs but not sure if these will be adequate. Will I definitely need a hard-core sub base, or do you think it should be ok on the slabs?
Cheers
do you know whats under the slabs? go for hardcore, by the time youve lifted them your already halfway there
about 40mm of sand on top of soil
