Concrete repair spur bolt size?
7 Jun 2021
What size bolts do I use on a concrete repair spur?
M12 from memory but different spurs different sizes. Measure the diameter at your local merchants, there will be plenty on display.
I've used M10, but the old ones I took out were M8 and still holding up fine after 30+ years.
'Not too tight in the hole' give you a bit of wiggle room if you need to adjust the post a few mm either side.
As the vicar said to the choirboy!
