Hi.
I have just inheritated a 14' x 20' garage with a concrete roof. I estimate about 70 years old.
The roof is in 3 sections with rsj's in between. Above the door is a 12' long RSJ supporting a 5' high 9" brick wall.
This RSJ is so badly rusted, the edge I can see is only about 9mm thick with a mass of flacking rust.
The other two RSJ's have rusted to the point they have pushed forward the two concrete slabs 50mm
I estimate the concrete to be 150mm thick with 18mm reinforcing. Can see a piece of reinforcing where the concrete has dropped away. Also there is many stalactites where rain water has seeped through.
My intention is to demolish it to the level 2 bricks below the concrete slab and replace it with a wooden roof.
I cannot get any plant near it so I will be demolishing it, brick by brick with an electric rock breaker / chisel as my main tool. Obviously well propt up with acrow props.
Anyone any idea if the concrete is likely to have one or two layers of reinforcing and will the concrete have deteriated at all being 70 years old.
Many thanks.
Many thanks.
