concrete shed/greenhouse floor
15 Mar 2009
Bristol
Hi all,
I'm trying to convert an old greenhouse into a garden storage shed, and I need to concrete the floor. Its half done already in that there is a central concrete path which I think is breeze blocks with concrete poured over them.
I've dug it all out the soil to about 6 inches below the concrete path and filled it with old breeze blocks and bricks, and am planning on sloshing a runny concrete mix in and puddling it about a bit to hold it together and level it.
From what I've read this is a bit rough and ready, but I don't need anything fancy. My questions are - is this OK or will it crack over the next ~10 years? And what mix of concrete do I use? Do I use a different mix to fill the gaps and screed the top layer?
thanks in advance,
Jim
This should be fine, it wont be the most reliable of jobs but it will do what you need, along with this it should last a good amount of time.
