Concrete slab roof thickness
30 Dec 2018
Up North
At the rear of my house, in common with several similar houses, we have a single storey utility room, combined with a one time toilet and a one time coal store when built in 1955. That was revised, refurbished by demolition of a brick dividing wall, to make a larger, better insulated utility room, with the toilet moved into the main house and a pointless store room. I later modified that, by knocking a door way through from the utility room into the store, to make a much needed pantry, bricking up the original separate door.
A neighbour is in the process of demolishing the entire thing, to build an extra ground floor bedroom, plus utility, which has given me the chance to better see the original construction. of the concrete slab roof. The slab is around 4.5 inches thick, cast in place and has no steel reinforcement at all - which rather surprised me. Would the lack of reinforcing be normal?
The entire space is roughly 11.5' x 7', with a 3' wide pantry taking up 3' of the 11.5' length, accessed via the middle of the 7'. As you enter the pantry, there are deep shelves on both your left and right.
