Trying to work out whats actually necessary for a small indoor slab covering around 3x3 m. It is reinforced by a single layer steel grid and should be 5 inches thick. It isn't the final floor surface so doesn't need to be perfectly smooth. I am mixing the concrete myself.
I have decided that:
I don't need a vibrating poker because the slab isnt thick enough and the grid is 200x200mm
I don't need to power float it given the small area
I probably need a long handled hand float (like a bull float ) for rough levelling. Does this seen reasonable?
Are there any good alternatives to hiring a bull float for a small area, such as planks etc?
