The problem is the location of the boiler requires a long run of drain for the condensate in order to reach the nearest acceptable drain. At least 2 metres will be external. Longer it internal works are to be avoided.
Proposed solution. Comments please, Run the condensate drain pipe inside another pipe. Using a small fan warm air from inside the house will be blown along inside this outer pipe to keep the condensate pipe above freezing point.
The proposed fan is the type used to cool computor power supply units, 4 inch square 12 watt or similar.
Theory suggests that the small fan could be supplied from the switched supply to the CH pump ( heat only, not a combi ) to ensure the fan runs only when needed.
