I have had 3 quotes for fitting a Worcester Boche 12 ri central heating boiler the best one appears to be a small company that does a lot of local work and appears to have a very good reputation. This firm were the only ones that mentioned the need for a pipe from the boiler to a drain about 10 feet away.
I have read up on this and it appears it takes away the polluted (acid) water from the boiler.
My worry is this.
the drain in question is not connected to the main drain system its a soak-away type drain for the roof drain pipe that soaks away into my front garden.
Am I worrying over nothing.
My worry is this.
