condensate pipe leaking inside and no hot water
9 Jan 2010
Peebleshire
We've had no hot water for 3 days however the cold water and central heating is working fine, so I am assuming there is a frozen pipe somewhere?
I have also just discovered that the condensate pipe coming from the boiler (Worcester 24i HE) is leaking. The pipe goes from the boiler through the external wall and drains outside but it is leaking inside from a join in the pipe close to the boiler itself. The condensate pipe has frozen a couple of times outside recently (knocking out the heating) but I just defrosted it using a hairdryer and the boiler re-started no bother. Why is the pipe leaking and is what can I do about it? And I take it I just have to wait for the thaw to get the hot water back?
Thanks for any advice!
the reason the condensate pipe is leaking is because whenever it has frozen up the condense water builds a pressure up in the pipe forcing a leak out, and you could could try a hair dryer onto the cold inlet of the boiler or even keep a few heaters near it and it will eventually thaw out.
