condensate pipe question
30 Nov 2014
Staffordshire
Hello All, At the moment my son's home has a upvc condensate vent pipe. This pipe feeds down the cavity (brick outer/timber inner!) to a 'suitable' distance from external ground but as sod's law decrees it has sprung an internal leak presumably at the 90 degrees bend. My boiler has a 15mm copper vent pipe so my question is...Can I replace his upvc pipe with a 15mm copper run thus eliminating any chance of leaks. Thanks. mikew070319
No, the condensate is acidic and will eat through copper. Plastic only for condensate. Your boilers pipe in copper may be the pressure relief valve pipe.
As Said, Condensate is acidic and guaranteed to rot and cause leaks on copper.
If you can fit it in, SpeedFit/Hep20 22mm Elbows will grab onto the 21.5mm condensate pipe very snugly and are quite a bit stronger than the little glued fittings (they have glues them havent they?) but the problem is they do take up a lot more room and need clean unglued pipe ends to grab onto
