Hi all,
Had a new condensing boiler put in my loft (to replace my old combi boiler).
Needed a condensate drain connecting.
The installer attached 22mm overflow pipe to the boiler. This pipe then goes into 32mm pipe which runs outside. As far as I understand, this is correct to use 32mm outside for issues of pipes freezing.
However, the 22mm and 32mm pipes aren't "connected" as such, instead the 22mm pipe "sits inside" the 32mm (hard to explain, please see image).
Is this normal? It seems to me that if the 32mm pipe froze (which is probably very unlikely), then condensate could overspill? Should there be a 22mm > 32mm adapter of some sort instead of simply putting the 22mm inside the 32mm?
Thanks for your advice,
Shockfire.
Shockfire.
