Hi, I've just moved into a house with a Ferroli F24 combi boiler. Everything seems to work ok but there is a leak on the condensate trap. It's coming from between the main body of the trap and the bowl hangs underneath that's held up by a plastic threaded sleeve like you find on waste traps. Is there supposed to be an o ring or washer between the body and the bowl? There isn't one on this and the bowl just kinda hangs there and rattles round.
thanks in advance
thanks in advance
