Hi there,
I've recently been suffering with condensation problems on the outside wall of a bedroom. It's an old house, so has solid walls and the occupants insist on breathing inside.
I'm looking at ways to improve ventilation.
The loft above has insulation directly above the ceiling covered by wooden boards, then the roof itself has more insulation between the rafters which are boxed in with plasterboard. The eaves seem to be fairly open; I can just about see sunlight where the roof meets the loft floor.
Would removing the loft boards allow humidity to permeate into the loft and disperse, or would this be counterproductive?
Other solutions I'm considering are a dehumidifier (easy, but doesn't fix the root cause), adding a wall vent (cold in winter?) or adding wall insulation (might prevent condensation, but make humidity even worse, v big job to fit).
I'd be very grateful of any wisdom members can impart.
