I understand how condensation is caused and the only good way to deal with it is to ventilate more (and I read the section in the wiki).
House has solid brick walls and condensation (leading to mould) is forming on the inner walls. Gable end wall has been dry lined so the mould is forming in the bottom corners where the non gable walls meet the gable.
My question is, how to subtly introduce more ventilation? Initially I was going to bore a 2 - 3" hole through the ceiling into the attic in one of the corners were mould forms. Followed by an air brick in either gable to ventilate the attic space.
Does that sound a sensible first step to see if it helps or will I need to install an extractor fan to get any worthwhile air flow?
