Condensation in loft
7 Dec 2007
Hi Guys
I've looked around and seen a few posts but none seem relevant to my issue - Help Appreciated
Just moved into a new house and the roof was re-done (before I took ownership). It is a tiled roof and looking at it from the inside of the loft there is a black cloth/nylon like covering (no signs of insulation other than this lining)
Last night I went into the attic and found condensation around half way up the black cloth (literally dripping). On closer invetigation found white mould (?) on a lot of the beams.
I have just spent a fortune on my house, and fixing other issues - PLEASE tell me there is something I can do ...
you need ventilation
either in the roof or around the eaves which requires the insulation stopping short by around 6 inches
the discoloration may be from before the roof was fixed
also assuming you have entered the attic on several different occasions recently or left the trap door open in the attic that can introduce lots of moisture that cant escape without proper ventilation
I had exactly the same problem in a new house (7 years old) , wringing wet condensation after cold frosty nights; this despite having vents in the soffits. Since then got advice from this forum and have installed a vent at each gable end. Problem seems to have been solved.
BTW Can anybody please tell me what the Building Regulations currently demand for Roof ventilation?
