I've recently fitting 230V outside lights down my drive, they are plastic globes on one metre high poles off the ground. In this cold weather the plastic globes are continually filling up with condensation. I've fitted the suppliers 'optional' rubber gaskets to seal the plastic globe to the base, and sealed the cable where it goes into the base but this does no stop it. Can anyone please inform me if it's possible for condensation to form in a completly sealed plastic globe? I'm assuming that cold air must be getting in somewhere, and when warmed by the bulb then forms condensation on the inside top of the plastic globe which then runs down into the base. When I remove the globe the base has about 3mm of water in it each time.
