I will be changing my old combi boiler soon, my question is will the fitter be able to branch into my kitchen waste pipe with condense pipe or will a seperate continous pipe need to plumbed out to the outside drain.
The waste pipe is about 10ft from the boiler ,the condense pipe would have to fit behind the units to reach the internal waste pipe,to do it from the outside would mean a ugly looking pipe running along the outside wall,does this mean removing all the backs of the units to fit the pipe or can you buy some sort of flexible pipe,is there a problem if there is an electric oven backing onto the same wall thanks.
wants to be a rigid pipe not flexible. Its definately prefferable to run internally though as it prevents it freezing. shouldnt be a problem behind oven as long as there is reasonable clearance, not touching etc..
