Hello chaps,
Wondered where you run the condense pipe from a combi if its fitted in a loft? Do you just run it as an overflow ? If so does it drip much.
Thanks for your help. My gas fitter who is running up a new gas feed, doing the final connections and commissioning is fishing in Ireland at the moment so I was just after a bit of "friendly" advise so I could get as much done as I could for him. I am a HETAS installer so can cope reasonably well with the wet side. Been to our local merchant to get the pipework and they put me right so thanks anyway.
