Any suggestions welcome.
The boiler is approx 4 years and manufactured by Gerkros (Ireland based or was as they are now bust). The boiler s fitted with a Riello Burner.
Over the past few weeks the boiler switches on for a short while and then stops and looks like its starved of fuel, the tiger loop empties and the pump seems to fail to do its job. Weve had a plumber out twice now and suggested it cant be the pump as there is no in between with a pump it either works or it doesn't. A solonoid and a control box unit were ordered as new parts to trial to see if it made any difference. Following the control box being replaced. The boiler fired up and worked for about an hour before the same thing happened ie. cut out starved of fuel. I think even the plumber is scratching his head to what could be the problem. Could it be a faulty pump ??
Any suggestions.
Thanks in anticipation.
Any suggestions.
