I've had a Baxi Solo fitted and the plumber ran the outlet through the external wall and down to ground level. I was intending to fit a soakaway 1m away from the house. I noticed on one of the posts that someone didn't recommend soakaways. I have a soil pipe (about 150mm diameter off the top of my head) running inside the kitchen so was wondering if it would be possible to run the condenser outlet across and tap into this. Is it ok? Anything to consider? I was wondering what fittings to use? The condenser outlet is 22mm I think. All replies gratefully received.
Cheers
Ted
Cheers
Ted
