Having removed burner and electrode from Keston 170, was amazed by the amount of calcium build up inside the heat excanger, the top coil was completely encrusted with the stuff and a large build up in the base of the centre chamber. Is this normal or indicative of condensate drain problems or incorrect burner setings ( the burner looks fine) Heat exchanger only about 4 years old.
