We have a large farmhouse with a decrepit oil boiler and need a modern heating system. We are on heating oil, but would like to use solar hot water heating and ideally the solid fuel Rayburn in the Kitchen.
Our power requirements have been estimated at 200000 BTU by two engineers (all rads together)
Fou rquestions really
We have been recommended a condensing boiler, but are these reliable with oil. Do they fail prematurely due to suplhites and corrosion?
The Archie Kidd boiler..is it a better option?
My wife really wants a mains pressure hot water system, so assuming are flow rate is enough (which it may not be, as one engineer has assessed it at 19 lpm, but that may not be accurate) how do heatbank / thermal stores compare to an unvented type cylinder?
Can the rayburn only be plumbed in to a traditional gravity fed system
Cheers
David
ps How do you work out your flow rate into the house
pps Apologise for any terminology cockups as this is not my field, just the owner of a chaotic house
Cheers
David
