Condensing Boilers.
30 Jun 2008
Suffolk
Thinking of getting a new boiler after Christmas and know that it has to be a condensing type.
With regards the 'condenser' pipe outlet I found this in the FAQ's section.
Water coming out of a white PLASTIC pipe will be from a condensing boiler and is normal. It must go to a drain and not allowed to dribble on the ground!
Does this mean I would be allowed to run it into the guttering of my conservatiory which then runs into the drains?
(By 'I', I mean the installer).
Thanks in advance.
yes , i believe you can now run it into plastic gutters , but i would suggest some mesh cover for the gutter incase of blockage. i;e leaves.
Thanks Fitz,
already got one of those cages over the downspout. ;)
