My Bosch condensing combi boiler was flagged at risk weds lunchtime because the installation was faulty. The flue was wobbly because it hadn't been supported. The condensing pipe outside was also too long. I'd called British Gas out because it wasn't working but he couldn't touch it.
Called the installer who said standards have changed. Checked & found that's not the case with my boiler. They sent someone around on Thurs morning. He agreed the installation was faulty & showed me the inside of the flue which looked rusty. He said the flue should've been set at an angle. He said he'd send photos to his boss they'd call me with a time to fix it. He said they'd treat it as urgent.
3 qu
1. How long is it reasonable to wait for the work to be done (especially as the fault I called BG out for in the first place won't be fixed then so I still won't have ch)?
2. Could the fact that the water didn't go back to the boiler damage the boiler over time? It was installed early 2009.
3. My condensing pipe froze a couple of times. Would that've been less likely with a properly installed flue & shorter external pipework?
Thanks for any advice you can give me!
3 qu
