Condensing dryer making noise
6 Dec 2007
Dundee
I have a Zanussi Lindo 300 condensing dryer and it suddenly started making a noise - it actually sounds like a bit of paper is against the drum and you hear it kind of swishing when the drum turns.
I've taken the top and sides off and the belt is fine and I don't see anything obvious wrong with it. With the dryer out and top and sides off, it sounds like the noise could be coming from the back of it.
I know it's a vague description, but anyone any ideas? It's less than 2 and a half years old and of course, the 2 year warranty has just run out
could be worn rear drum bearing or drum pads causing the drum to rub on the drum seal as it turns.
Is there a way for me to check that? Although the belt is intact and doesn't seem loose, I can turn the drum really easy by hand - like with a washing machine - and I thought tumble dryers were harder to turn by hand
with the lid off, turn on the dryer and watch the drum turning. does the belt slip? is the drum def turning?
how did that get there?
holes in your lint filter possibly or perhaps its not fully sealing the filter housing
It had went under the tumble dryer and got sucked into the fan at the back according to the man who came out
It could have been worse.................
it could have been a Waitrose receipt lol
