Good Morning,
Was looking to tidy up wiring in the loft over xmas/new Years, but got stopped in my tracks once i noticed a fair amount of condensation on the felt layer and wetness on the roof joists.
Time line is as follows:
Pre Nov 2015:
loft insulated with two layers of fiber glass compressed into 100mm space between ceiling of room and floor boards in loft.
roof was straight tile (and lots of daylight).
Nov 2015 - had internal chimney removed, and roof re-tiled (many of the tiles were crumbling or already broken). Flet layer introduced, and new tiles, sofits attached to existing boards.
Oct 2016 had ground floor rendered and plastered, and upstairs landing, Heating system switched off and replaced - occupants moved out.
Nov 2016, some heating turned back on to assist drying of plaster, fiber glass insulation removed and celotex installed over 3 weekends. Note the rear of the property was done first but not sealed with foam. front of the house done next, and was sealed, followed by the center also foamed (loft is roughly divided into three sections based on joists).
16th Dec 2016 heating back up and running, and occupants moved back in.
30th Dec 2016 went up to tidy wiring, noticed large amounts of condensation to the rear part of the roof, some along the side and a bit at the front. Note it had been foggy outside for about 4 days prior to this nearly constantly not just in the mornings.
2nd Jan 2017 foam sealed the remaining part of celotex (back of the house).
Some other notes re the house:
The rear of the house backs to a park.
The side has a shared alley way followed by another property - approx 5-6m distance.
The front is to a road, with houses on the other side - approx 15m distance.
The bathroom is to the rear of the property, and currently the extractor fan is not functioning. - Prior to new heating system water wasn't hot enough to create loads of steam, plus door was left open while showering. Since moving back in on the 16th lots more steam when showering, plus door is now closed. And i am looking to find out whats wrong with the fan and get it changed/fixed asap.
There is also condensation around the edges of the roof, where the joists meet the outside walls, where there is currently NOT any insulation (cutting celotex to fit the gaps is time consuming!) and also where there is existing fiber glass.
There are no vents as far as i can see, both in the roof tiles, and in sofits (didn't need it prior to reroofing as i could see daylight in more places then i can count in my fingers and toes!)
So what are my steps going forward to reduce/remove the condensation:
Can i just foam fill the gaps where joists meet the outside wall (on top of the sofits)?
Foaming the remaining areas i hope will reduce a fair amount of the heat getting into the loft so reduce condensation. (done yesterday 2nd)
Fix Fan (in progress)
Pre Nov 2015:
