Hello,
i have a Worcester Bosch HE 30 Plus Combi that's been working fine for many years.
Yesterday I noticed that there appeared to be some water leaking onto the digital control panel originating from within the boiler case.
I've investigated this (by removing the outer boiler casing) and found that when the boiler is running, drops of water (presumably condensate) appear from what looks like a green gasket - it looks like the mating surface between the flue turret (that sits on the top of the boiler) and the boiler flue socket (from within the boiler).
Worcester Bosch have said that occasionally the seals do go - my boiler was fitted in ~ 2002 and have given me a part number for the replacement seals pack (87110043290 - apparently, I just need the green one and not the black one).
Some time ago I noticed that occasionally drops of water would accumulate on the outer surface of the flue (the metal pipe that supplies air to the boiler) but this seemed to stop of its own accord.
I was concerned that perhaps water was running down the air intake and leaking back into the boiler.
Which appears to be the most likely?
1) the green seal has just given up the ghost because its now old
or
2) there's a further problem with my flue pipes, the internal seals of which have perished too leading to condensate running back into the boiler but via the air intake route?
the boiler runs fine but clearly I want to avoid water getting anywhere near the board etc.
Thanks in advance
or
Thanks in advance
