Are they/can they be made waterproof? Steel or plastic versions.
https://www.tlc-direct.co.uk/Products/MT25BX1B.html
I need to run some SWA under ground to a garden light, taking the cable from an existing garden light (so extending the chain of lights) that's fixed to the house.
The run down the house is quite long and I'd like to avoid exposed SWA running all the way down (and butchering the bottom of the light for the SWA to come out!), so thought about taking some T+E inside the house, down a boxed in void and back out the house just above the DPC.
A surface mount conduit box would have the T+E crimped to the SWA. The distance from the patio to the conduit box is 350mm (if that) so would be far less noticeable. I would mount it as close to behind the soil stack as I can to hide it further.
Or are these a much better choice (but not as good looking): https://www.tlc-direct.co.uk/Products/MKK56506.html
The lighting circuit is on a 6a MCB.
Thanks.
Thanks.
