Hi All
I need for form a conduit now through which will run a new gas supply.
The new supply will probably be something like 32 mm Outside Diameter, 27.6 mm Inside Diameter in YELLOW MDPE (PE80) GAS PIPE. I am building a new wall and stair case at the moment ( in concrete) and need to provide a conduit for this gas supply ( pipe within a pipe aka new regs ). It will NOT be a straight line ! probably need 2 x 45 degree bends ( possibly 30 )
BTW - I've picked this size as it's closest to the existing metal supply pipe.
Any ideas what I should be using? I've been looking at 4inch soil pipe fittings but I'm totally clueless on this.
Thanks again
wert
Thanks again
wert
