I use a step drill myself I think I got my set from Tolstation just a cheap Silverline set has lasted pretty well mostly for plastics (lots of holes in plastic planters for the Mrs in the garden) a fair bit of aluminium and the odd steel cut.
Material: HSS Steel. With the Titanium coated to reduce friction and heat. Finish: Titanium. Ideal for using to cut holes in a variety of materials including steel, brass, wood, plastic,copper, fibreglass and PVC etc.
