Fairly new to this DIY Game.
Replacing a stand alone electric oven with an electric hob and single oven.
The fuse at the consumer unit is 32A.
The consumer unit is linked to a terminal outlet box, on a radial circuit, with 6mm wiring. Between the terminal outlet box and the consumer unit is a control unit with a built in socket. The control unit is about a metre from the terminal outlet box.
The hob to be fitted has a power rating of 6.2kw.
The single oven has a power rating of 2.25kw. It has come with a cable and 13A fused plug.
Can I just connect the hob to the terminal outlet box, with 6mm cable, and connect the oven cable to the same terminal outlet box?
Should I replace the control unit for one without a socket?
Do I need to install additional fuses for the hob and oven?
Does diversity apply to cookers and hobs?
Girlfriend is worried I am going to burn her flat down!
