Hi all, I have spent the last few weeks reading through various posts on this website about installing a pump in our house. The current set up is a gravity fed system, with both solar and geothermal heating of the water. It is a new build but from the time we moved in the pressure in the system has been terrible. So I've finally bitten the bullet and decided to install a pumped system. I've bought two single impeller pumps (Stuart Turner 46419 Monsoon 3.0 bar) but am looking for some advice on where to best place the pumps. I've attached a rough diagram of the system in the house. Now I know that best placement would be beside the hot water cylinder, but as we have a geothermal heat pump also heating the water, we have a second hot water cylinder on the ground floor, which seems to be fed from the 1st floor hot water cylinder. So if you look at the diagram would I be right in saying that the 1st pump should connect to the cold feed from the storage tank which is going straight to the cold outlets (I've marked the pump with an X), but should the second pump be attached at point A, B or C....or none of them I might be completely wrong with all of this so am hoping someone far more qua than I am can have a look! Thanks for all the help, Conor
