I'm confused. Where a pitched roof runs with a wall to one side do you have soakers (lead under tile) and then flashing on top of the tile as well, or is it one or the other? And do I use soaker secret gutter?
Plus the wall is to rendered so is the top flashing just screwed under the stop bead or do I cut a channel in the blocks? Everything that google turns up seems to be brick based.
BTW tiles are double roman.
