confused - kitchen foil on walls.?.??..
5 Jun 2006
Leeds
I have started to remove the wallpaper in the hall ready for re-decoration. When I pulled the first bit of paper off, it came away really easily, great I thought. My joy was short lived as once the bit had come off, I noticed there was kitchen foil on the back. The external two walls appear the have been covered in this way, the other 2 internal walls just have paper on them. The paper has then been covered with emulsion.
It looks like the walls were first 'papered' with kitchen foil, then the wallpaper put up afterwards.
I have never seen this before and am worried its been put there to hide something, no idea what though. Any idea whats going on here?
Maybe some of the cybermen used to live there.... :rolleyes: ..........or...there is, or has been a damp problem on the exterior walls. The stuff in question is called foildamp and its foil backed lining paper thats put on with a special adhesive which is resistant to water.
You may have a rigt job in getting it off...id get the existing paper off, prepare the walls and then line them.
If it gas been hung correctly there will be overlaps on the joints so you may have small ridges on the surface..fill em over before you line.
