Hi there.
I woke up the other morning and realised that my central heating was not on as expected.
The acutator should have been in the middle position to feed both the hot water tank and the central heating - however, it was in the water only position (to the right), despite the thermostat trying to get the central heating up to temperature.
I did some testing and here is what is happening:
With no water tank or central heating request, the acutator stays in the W position.
If I turn the heating on, nothing happens.
If I turn both the heating and water on and manually move the acuator to the M position, it stays there.
If I turn just the heating on and manually move the actuator to the M position, it automatically moves to the H position.
When in the H position, if I turn the heating off, it automatically returns to H.
When in the H position, if I turn the heating off but leave the hot water on, it automatically returns to M.
Really weird - in light of the above, the motor seems to be working. I even popped to Screwfix for a replacement but have the same issue.
The problem, therefore, is the default W position - the motor seems to get no signal to move when it is in that position only.
Any advice on how to potentially fix would be greatly appreciated, or am I looking at a whole new unit?
