confusion
12 Jan 2006
Can anybody help? I currently have a glow worm boiler, with a cylinder at the top of the stairs; a header tank and an expansion tank in the loft, I would like to remove the header and expansion tank. I would like constant hot water and have good water pressure for a mixer shower. my problem is i do not know which is best, a condensing combi boiler, or an upgrade to my existing system. which is more economic or indeed which is better. many thanks :confused:
not sure all i know is it uses a fan to keep the pilot light on which needs replacing as well as looking pretty old was thinking of replacing it anyway :eek:
sounds like an ultimate,probably best wood be new unvented system .i:e new boiler and mains fed cylinder.
is this what is known as a pressurised system, do you think it is a better idea to do this rather than convert to a condensing combi
many thanks for the advice. last question. any particular brand of boiler i should go for?
