I have dug a hundred years of mud and gravel out of the consumers' stop-cock pit. Inside I find it looks like it is on half-inch copper stubs wiped into lead pipe of same internal size.
I* am going to replace the pipe to the house with a new plastic one, due to a leak. The adjacent water meter in the pavement has a T-handle to turn off the supply (though at the moment Thames Water have taken it off due to the leak)
1) What should I use to connect to the old copper stub? The old stopcock is (probably) a hundred years old, will a modern fitting go straight onto the old nut, and will it be a compression joint with an olive?
2) Should I take off the old stopcock or leave it in place? It is very stiff but is not weeping. Do I actually need a stopcock in that pit at all or can I just connect plastic pipe to the stub?
3) since the old pipe from meter to stub is half inch, will I gain better flow by using 25mm plastic, or may I just as well use 20mm? (I happen to own a coil of 20mm already)
My instincts are to do a first class job, but this house is being sold shortly so I don't want to give myself additional effort and expense without benefit to me. The brick pit is 23" from rim to floor, and about 24" x 18" with an iron lid. The run to the house is about 10 metres where it turns up and goes to the kitchen sink and loft tanks, I can put a stopcock here if I is worth it.
the pit
View media item 23857
this shows where the adjacent meter is
View media item 23858
* I am going to get the pipes, connectors and valves for the job
the pit
