I have a Chrome Bottle trap for a new bathroom which is being installed. When we tried to connect it up it seems the pipe from the trap is to small. I contacted the company and they maintain its 32mm pipe but when I try to connect to my 32mm waste the compression joint does not hold (its like its too big). Is 32mm the internal or external size of the pipe? If its internal then its likely that the plastic waste will be a few mm bigger (due to wall thickness).
Has anyone come across issues connecting chrome traps to plastic waste pipes (32mm) and is there a common fix?
mark
mark
