- Joined
- 26 Oct 2007
- Messages
- 4
- Reaction score
- 0
- Country
Hi All,
I have very strange case for the moment.
I have basin in the toilet.
This basin has one tap with inlet of 1/2" down the basin.
This tape was connected to water source of 3/8" outlet using the a non flexible pipe.
I want to connect the a new tap below the basin, so I did the following:
1) I got the following stuff:
a) 1 flexible metallic pipe of 50cm, one side is 3/8" and the other side is 1/2"
b) Y Connector
c) Another tap.
d) Teflon tap
2) I connected the 3/8" side of the flexible metallic pipe to water outlet using a teflon tap.
3) I connected the Y-Connector to old tap (below the basin) using teflon.
4) I connected the other side of the flexible metallic pipe to the Y connector using teflon tap.
5) I connected the new tap to the outlet of the Y connector using teflon tap.
The problem that when I open the water source, the water starts to drip in the Y connector from the old tap size, it seems that there is certain type of leak between the old tape, and Y connector only appears when the water is pushed upwards, how can I stop this dripping, as I tight it it very well.
Please help me in my question/
* All the pipes, and connectors are made of Steel
b) Y Connector
c) Another tap.
d) Teflon tap
