Connecting 9651 to Sd1 dialler
wire to your bell trigger is the standard way not the strobe, unless you have separate outputs, for Fire PA and alarm.
you would wire the bell trigger to C based on C being already programmed for alarm, but if you took it to any of the others you would need to setup a new message for alarm.
as for polarity, if when the dialler is connected it tries to make a call and the bell isn't active, reverse the polarity on the dialer input and fire the bell trigger.
