I'm decorating the bathroom, including replacing a stand-alone light-with-shaver-socket with a mirrored cabinet with the light and socket built in.
I've removed the old stuff, and am left with a pair of cables coming out of the wall, to which the old light-and-socket unit was directly connected.
The new cabinet has a flex, about 3ft long, for its power, so I envisage setting a metal box into the wall just above the new cabinet, which is where the cables emerge from the wall at the moment, and connecting the cabinet flex inside the box. Problem is I can't find the kind of connection device I envisage, which would be a flush face plate with a hole in the centre for the flext to enter through.
First off, is my proposal correct? Second, what is the face-plate-with-a-hole (and terminal block on its back) called? I presume I can't use a normal 13A plug and socket in that location.
