hi folks very sorry to have to ask for advice again but hopefully some can help me.
i need to put in a new foul sewer line which is fine i got my head round doing this. However the problem i have is how to connect into the sewer
The manhole is brick built1.5 meters deep. the main sewer pipe at the bottom of the manhole is a half pipe with sloped sides (sort of a catch pit)
our current fowl sewer line drops in about 600 mm down from surface level and everything drops into the main line below. Our neighbours line comes in at the bottom (1.5m depth) at about 45 degrees to main line.
here is my question can i legally break into the manhole and put a second feed in or do i need to get permission from severn Trent.
also what height should i break in i was thinking about 400 to 500 mm above the base feed at about 45 degrees to the main pipe.
just to clarify i have to come into the main manhole as the current darain is 500 to high for us to connect into
hope this is clear your help would be welcomed. image below
//media.diynot.com/170000_169805_48711_77445835_thumb.jpg[GALLERY=media, 48711][/GALLERY]
