I plan to run a spur from my cooker cable, out to the garage and in to a blue c-form 32 amp socket. I then plan to plug in my welder which has a recommended fuse rating of 30 amps.
Due to the initial surge of the welder, it has been suggested that I fit a Type D 32 amp MCB in place of the old 30 amp fuse wire at the mains.
Does this sound OK? Should I also fit a PCB in the circuit somewhere?
