I'm looking to install a Mitsubishi Electric inverter air con/heat pump in a domestic premises. The model I am looking to go for requires a starting current and running current of 4.4 amps.
I've spoken to the manufacturer and didn't get very far on the electrical requirements (I'm going to try them again though), although I understand it is preferred that they are connected via a rotary isolator.
I had my electrician round and he thought it wouldn't be an issue taking off an existing socket ring, rather than its own circuit. His suggestion was to take an internal FCO connecting into an adjacent socket, with a rotary isolator on the outside connected to the FCU. I don't have a problem with this, although it involves an extra accessory next to the existing socket.
I'd be grateful if anyone has any further experience or views on how this air con unit could be connected up and whether the way proposed by my electrician is the standard approach. My initial naive thought was to get an external IP66 socket installed (which I could use for other purposes) and plug the air con unit into the socket with a standard 13 amp plug. Then again, I'm not to sure what the benefits are of rotary isolators over an FCU, etc, but I'm sure someone will point out.
Many thanks,
Damian
Many thanks,
Damian
