Connecting and electric cooker Beko BDC5422AS_SI Electric
20 Jul 2013
I bought and electric cooker,
I read up for some advice and disconnected the previous electric cooker, which was pretty straight forward the wire coming from the cooker into the box on the wall.
However we have just received the new cooker and they have taken the old cooker, and I realized there is not wire coming out of the new cooker just a box on the back of the cooker similar to the box on the back of the wall.
So i just wanted to clarify should I have disconnected the wire from the old cooker and kept this to reconnect the new one, if so , So now i need to purchase another cooker wire suitable for the volt then connect this to teh cooker then connect this back to the box,
grateful if someone could confirm>
Best
Yes you should of disconnected the wire from the cooker. You will now need 6mm twin&earth cable and earth sheathing .
Ok, yes just reaslied after they had taken the overn away. thank you for your help :)
