connecting bar shower help
19 Mar 2007
hi guys how do i connect this bar shower to the fixing kit that ive put on the wall ?....as you can see ive left a good length of pipe sticking out frpm the wall....do i simply just cut off the extra pipe flush with the threaded unit on the wall and simply screw on the bar shower to these exposed thread ?...i dont see any rubber seals with the kit, however my bar shower has two gauze type rubber seals that i kept when i removed the shower...ill use plenty of ptfe tape as well...see pics...bar shower is just resting on the pipes...lol, just thought id show you guys,,
Yea the pipes need cutting back
Ptfe is useless in this situation you need 2x 3/4 rubber or fibre washers if none were provided go to a plumbers merchant or DIY shed to pick some up
i did cut the pipes flush....used plenty of ptfr tape...tightened up the bar shower....and it started leaking....are you sure the pipes need to be cut flush...as i cant see how a seal will be formed onto the bar shower??????
What are the fittings on the wall likedo they not have a compression fitting inside?
Or are you just sliding the pipe through them?
http://www.youtube.com/watch?v=XuLTG9oB1T8&feature=youtube_gdata_player
This is the sort of fitting I normally use
yes its exactly like in this video...exactly the sample principle, however, i didnt leave 20-25mm pipe sticking out from the wall...and also probably leaked cos i dint have any washers in the bar shower when i screwed it onto the threaded bit....ill get some washers tommorow and will do it again..
i got it from here
http://www.ebay.co.uk/itm/220992666054?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
If you've not left enough pipe sticking out of the wall it'll never seal, you'll need to re-pipe it. Are you sure you assembled the kit correctly and tightened it up properly? Don't use any PTFE tape anywhere in this kit, it won't help it seal, it'll just look awful
ok took it all off and done it again..as before no leaks this time...fitted the 3/4 " filter washers...only thing i changed was the pipe, i previously used chrome plated 15mm copper pipe, seems like the olives wouldnt seal on it as it was smooth and shiney, olives proabably slipped back when tightening... changed to normal 15mm copper pipe...sealed fine no leaks...happy boy...lol.. :LOL:
